SpotlightEditing lighting devices
Once lighting devices have been inserted, many of the parameters can be changed from the Object Info palette or Lighting Device dialog box, and the color, numbering, alignment, and other options can be set.
When you need to edit many lighting devices at once, use context menu commands to select devices by certain criteria. You can select all the lighting devices with the same instrument type, position, rigging object location, or focus point.
Selecting lighting devices by instrument type
Command
Path
Select Lighting Devices by Instrument Type
Context menu
To select all lighting devices with a particular Instrument Type value:
Right-click on a device that has the desired instrument type, and select the command.
All lighting devices of that type are added to the current selection.
Selecting lighting devices by position
Command
Path
Select Lighting Devices by Position
Context menu
To select all lighting devices with the same lighting Position:
Right-click on a device on the desired lighting position, and select the command.
All lighting devices at that position are added to the current selection.
Selecting all lighting devices on a rigging object
Command
Path
Select Lighting Devices on Rigging Object
Context menu
To select all the lighting devices on a particular rigging object or hanging position:
Right-click on the rigging object/hanging position, and select the command.
All the lighting devices on that rigging/hanging object are added to the current selection.
Selecting lighting devices by focus point
Command
Path
Select Focused Lighting Devices
Context menu
To select all the lighting devices aimed at a particular focus point:
Right-click on the focus point, and select the command.
All the lighting devices assigned to that focus point are selected in the drawing; all other objects are deselected.
Lighting device properties
Changing device properties
Advanced light properties
Lighting device color
Replacing lighting devices
DMX patching
Changing the label legend
Refreshing lighting device and light position data
Aligning and distributing Spotlight items
Numbering lighting devices by hanging position
Find and modify
